FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Golf Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 10-12-2017, 10:48 AM   #35
Gti jake
Senior Member
Drives: GTI 6MT
Quote:
Originally Posted by Blade3562 View Post
As you go up in tiers the SBC ones get pricey. I want the extra insurance of a Stage 3 Endurance for the inevitable IS38. I also hate the stock clutch feel, a heavier clutch should fix that.
For what it's worth I wouldn't install a SBC in my car if it were free, let alone paying a premium for one. I've personally seen them fail to hold the torque they're rated for on diesel trucks and mk6. Ik neither of those are mk7 but that's enough for me.
__________________
'16 GTI 6MT PM for NC/SC help with Installs & Fabrication
Gti jake is offline   Reply With Quote
Old 10-12-2017, 02:09 PM   #36
russiankid
Senior Member
Drives: Das Auto
Interesting, 1.8T clutches are half as much as 2.0T clutches I had only priced out 1.8T ones. It'll be closer to $2500 then. I'll be running the SBC Stage 3 Endurance 2.0T cost $1750, 1.8 cost $950.
Would be interesting to see if somehow we could get the 1.8 clutch to work on a 2.0. You could do a SRE clutch with a new DMF for roughly $1,000.
russiankid is online now   Reply With Quote
Old 10-12-2017, 09:52 PM   #37
Ironshade
Member
Drives: 2015 GSW 1.8tsi 5MT JB4+is20
Quote:
Mine was rated for 470tq. My car made close to 600tq at the crank With shit load of antilag awd launches. Hot lapped it at drag stip for maybe 10 passes running 11.1-11.3s and clutch held. Organic disc starts feeling like butter when they heat up but still. Awd running NT05s it held. Gotta keep in mind lots of people install them wrong. You NEED to clean of flywheel from lub before install with a grease remove. “I used thinner” lots of failures are customer errors. Especially when from my experience SB underrates their stuff.
Ironshade is offline   Reply With Quote
Old 10-13-2017, 05:11 AM   #38
Blade3562
Senior Member
Blade3562's Avatar
Drives: 2015 Golf LE
Quote:
I hate dual mass flywheels with a passion. I also know several people with South Bend Clutches that have fun them for years and loved them? I'm not sure what the difference between the 1.8t/2.0t clutch and flywheel are but I'm going to assume the spline count is different on the input shaft. The crank pattern should be the same, but we'll find out here soon enough!
Blade3562 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
