SugarMouth
- Nevada
Has anyone been successful getting the subframe aligned with their alignment or was the subframe alignment an extra cost?
Are you talking about the front lower frame? Is this not part of alignment? Are you talking about a Tyrolsport bolt kit?
My subframe is off a bit and I want to even out front camber. I want it centered with a tap and a retighten. Has anyone been successful having this done within the cost of the alignment?
Shifting the subframe is part of alignment if front camber isn't sufficiently even.My subframe is off a bit and I want to even out front camber.
However, it's still a matter of debate what 'sufficiently even' does actually mean.
Volkswagen allow for huge tolerances unfortunately, say half a degree difference
left/right.
This is way too much for my tastes, I wouldn't accept that much. So if your shop
strictly relys on factory spec you'd need to convince them to align to closer tolerances
(as close as possible). To be fair it's not worth the hassle if there's just 10' (minutes)
= 0.17° difference left and right hand.
left/right.
