Helix Sound upgrade dongle official rental thread!
BlueHen
Delmarva
Not true. Even the default settings sound massively different than the stock stereo. Are you sure you pressed the button in and let it load? There is a considerable difference.
You may have misunderstood him. He said he got much improved sound over stock; just that the programming did not improve it noticeably any further.
I had the same exact experience. My soundbox sounds very nice; much improved over stock. Then when I properly programmed it with the dongle (dialed up 57 for 4-dr GTI, pushed in button, got dots then PF), I noticed little, if any, difference. The most beneficial tweaking of the box after install for me was adjusting the gain screw. I set it at around 75% and it has very nice, deep bass, but not overpowering/clipping.
rawrmcrawrrawr
Irvine, CA
2018 Audi A4
There is a difference between the Jetta and golf programming. As soon as I programmed my sub to 35 for the Jetta, the bass got much louder and it sounds much better. I guess that makes sense since the subs in the trunk and not in the cabin like with the golfs.
Sent from my SM-G925T using Tapatalk
StealthGTI
Newport News, VA
2017 GTI Sport
Hello,
Just an update, I programmed my helix with the dongle and really didn't notice any improvement to the sound. I think I may have received one of the helixes that were preprogrammed.
I concur with these two observations. My sound changed, just not dramatically. That said, I still think this dongle rental thread is a great idea, even if for some it only serves to make sure the job is complete. :cool:
I hadn't messed with my gain screw. My system sounds good, especially now that my subwoofer system is tweaked. But it's a good reminder to know that the screw is there. I've been contacted by someone who says his Helix sounds terrible above about 30% volume. I wonder if his gain is cranked too high and causing problems. I'll have to contact him to have him tinker with it.
Scott
BlueHen
Delmarva
Stealth, just make sure to use a true eyeglass repair size Phillips screwdriver. The smallest one in my toolbox, while small in its own right, was still too big to turn it. Go to the reading glass section in the pharmacy area at Super Walmart and they sell repair kits for like $1.99. :)
rawrmcrawrrawr
Irvine, CA
2018 Audi A4
When you adjusted the gain screw, did you turn it up or down? Do you know what it's set at initially?
BlueHen
Delmarva
I wasn't able to discern where it was initially. Clockwise adds gain.
Save yourself time by adjusting it with the system playing, preferably something with prominent bass. The change is unmistakable when you are adjusting it. At 40% volume, you can swing from barely any bass to clipping like crazy.
wy2sl0
Ontario
There is no time alignment from the factory. That is the single biggest improvement of SQ with a DSP (this setup). Most people probably don't notice it, but that is the key to somewhat accurate reproduction. I see most people here talking about bass which is not really a factor in SQ.
crazyivan45
Memphis, TN
I received my dongle today and turns out my unit was indeed not set to 57 from the factory. With it reflashed the bass is much punchier and the highs and mids are not as shrill. Very pleased. Mine is also for rent as these things seem to be a rare commodity, PM me for info
CRK DDY J
Johnstown, PA
PP7e sub still for sale? (Loan dongle?)
Just a heads up everyone, I'm selling my helix PP7E sub that is plug and play with this box, and won't make you lose your spare tire. I also have the dongle for programming, and I'd be happy to lend it out if you buy the sub.
Trying to reach you, copperbricks, concerning the purchase of the helix PP7e sub, if it is still available. I would also like to borrow the programming dongle as well. I live in western PA so shipping would not be too expensive. I own a 2017 Golf Sportwagen S 4motion and feel the PP7E sub would result in more bass than the helix soundbox sub located where the the spare tire goes.
The other option I am considering is purchasing a PP50DSP on eBay for use with the PP7e sub. I would still need to program this version of the DSP for my vehicle with a Micro SD card. The PP50DSP has a slot for a Micro SD card but no slot for the programming dongle and I am assuming the two DSP's program the same with the one that comes with the soundbox sub being a version with less external controls but the same internal DSP as the full-fledged PP50DSP. I suspect the vehicle specific codes are on the dongle's Micro SD card and I could insert the same card into the slot on the PP50DSP.
Regardless, contact me at jocro54@gmail.com to sell the PP7e if it is still available. Thanks, John
Can pay with PayPal
Hotfart
LFK Kansas
Dongle received and ready to go down the line.
Curious - what's this little guy? It was in the connection jack on the amp. Haven't given it a real close listen, but it doesn't seem to have an effect on how it sounds.
crxgator
Raleigh, NC
All the MQBs
It reverses the soundstage for RHD cars if installed.
CRK DDY J
Johnstown, PA
Rent programmable dongle
Hi crazyivan45,
I would like to rent the programmable dongle from you. I am in the process of ordering everything I need to a DIY install of the Helix Soundbox Subwoofer in my 2017 Golf Sportwagen S 4motion. Last item I need is the dongle. Let me know what you require to make this happen. Live in western PA and can use PayPal if you desire.
You can email me at jocro54@gmail.com
Thanks,
John
