Quick sway bar question
tknj99
Central VA
$323 is for both bars. You wouldn't want to be unmatched ...
Aha, gotcha.. good deal then.. if an RSB makes this much improvement, i can only imagine how much better things would be with the Front SB installed as well.. i'll prob stick as is for now as im very happy and then look to better tires in the future ..
paulgarnett6
Lamo
Sent from my SM-G935F using Tapatalk
Gawernator
Fremont, CA
In this kit what brackets are used with the front?
OE would have to be drilled out.
Not sure if usable after.
You drill the nuts out and they supply you with new hardware. You don't have to buy anything else besides the bars and use supplied bushing and hardware. I like the red Powdercoating too although nobody will ever see it haha
2slowvw
Moderator
VA
2022 Tesla Model 3
I also have the ST RSB and it's been great. You can get it super cheap, sometimes cheaper when auto anything has it in stock. Easy install, great performance.
Reason for my question was the picture shown of the kit had no brackets.
Quality of brackets would also determine choice for me.
They show bushing but not front brackets.
I know rears easy to reuse.
Gawernator
Fremont, CA
You reuse the bracket itself
Gawernator
Fremont, CA
Pretty sure more people are unmatched than they are matched. I've seen many more rear sway bar replacements than I have front/both.
Well it's not like the car will become horrible by stiffening only the rear
Gawernator
Fremont, CA
To get the front brackets off does one not have to drill out the nut as they are a press fit? Once drilled is the nut now not usable?
My Eibach fronts came with vw bracket mounted over bushing and on bar.
Not a simple remove and replace.
Sorry for questions.
They have a full color instruction guide on their website. They give you replacement nuts to replace the ones you drill out
B95zP
AZ
Yeah but it's $500 and Eurocode's is $323 and has adjustability. Kind of a no brainer https://www.ecodetuning.com/eurocod...-bar-set-mqb-fwd-chassis.html?category_id=650
Not really a no brainer my Eurocode front sway now is good for wall art or the recycle bin. Also if you screw up the OE removal you're in a bad place.
I'd suggest going APR w/ brackets(or other manufacturers with an included bracket), that way you can resell it.
Yes, and they don't sell just the special hexnuts, so if you remove the Eurocode bar you can't do anything with it.
Gawernator
Fremont, CA
What did you do to your sway? And any good fabricator could make new brackets if for some reason you really needed that. I have custom brackets all over my racing stuff
More questions.
The OE bar, when removed looked like the 2 piece bracket is pressed together.
It looked like it you drill out nut you would need to be very careful to not drill into lower bracket. I think a bar that uses a new and removable
Bracket/bushing would be best.
