How to replace 7.5 tail light for euro spec
Bromy9970
S.Korea
My Tail lights is a bulb type on Euro spec.
I purchased the DAP wiring to replace it with a 7.5 tail lights. However, the wires are different because they are not of the US type.
Below is my BCM connection number.
Left Outer :1-A71(Brake), 2-GND, 3-A60(Turn), 4-blank
Right Outer :1-C8(Brake), 2-GND, 3-C31(Turn), 4-blank
Left Inner :1-C10(Brake), 2-GND, 3-Blank, 4-C11(Reverse), 5-A72(fog)
Right Inner : 1-A65(Brake), 2-GND, 3-Blank, 4-A64 (Reverse), 5-Blank
I think some wires need to relocate up to another pin. I wonder how to connect pins Mk 7.5 and coding.
ZERO815
Köln Germany
2017 GTI SE DSG
Although the NAR wiring is not meant for ROW cars you can Re-locate both outer adapter harness wires from 4 to 3 and connect the rest according to the DAP instructions. Follow the attached coding list and you should be good to go.
You could have bought a fitting harness instead too. Just PM.
Bromy9970
S.Korea
[(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20] - 39
I could not change the coding above to OO. Because if I tried to change it, an error message occurred.(Error in input. please one hexadecimal byte, eg:ff)
The rest have been changed as you informed me.
But, The tail lamp operates normally. There is a alarm message that B133A 15[009]-Open or Short to Plus (I attached below)
Fault : https://drive.google.com/open?id=1sARY0HaTiXiTAb2TMPyn_wIrAfdt3Q_s
Channel : https://drive.google.com/open?id=1Jk-2AUJluHwJLDOvV6tYN1bFwwTX0V0A
ZERO815
Köln Germany
2017 GTI SE DSG
"I could not change the coding above to OO."
Did you try a single 0 (Zero) instead?
