Clubsport part numbers
Sway Bars
5Q0411303N front anti roll bar (sway bar) 24mmx 3.8mm (same as GTI PP)
5Q0511305AT Rear anti roll bar (sway bar) 21.7 x 3mm (same as GTI PP)
FRONT SPRINGS 5Q0411105GD (GTi PP 5Q0411105CC)
FRONT SHOCK 5Q0413031FN (same as GTI PP)
STRUT MOUNT 5Q0412331D (same as GTI PP)
BUMPSTOP 1K0412303F (same as GTI PP)
REAR SPRING 5Q0511115HL (GTi PP 5Q0511115HM)
REAR SHOCK 5Q0513029GL (same as GTI PP)
So as you can see (unfortunately) virtually no change between the Gti and Clubsport, TBH i am a little disappointed as i was expecting from the press releases about the cars that VW had reworked the suspension and uprated it with perhaps dampers and swar bar changes, Have the journos with the all inclusive VW paid trips to Portimao circuit just been describing 10% stiffer springs??
Some info about the suspension and down force on the car from an article with Karsten Schebsdat, the last part about different wind tunnels is very telling. Do we believe anything VW says?
Is there less understeer in this car?
"Compared to the base GTI? Definitely. We have changed the roll stiffness distribution so we have more neutrality. We have softened the front bump stops and increased the spring rate on the rear to give the car more mechanical grip on the front end so we have less understeer."
How important is the multi-link rear axle compared with the twist beams used by most rivals?
"I think it's a big advantage, especially when you compare the range you can implement into the car. With respect to lateral dynamics with a twist beam you have only two bushes that connect the axle to the body and you have a lot of functions to implement into those bushes. Right now with multi-link you have separation of the lateral control to the longitudinal control so the spread is much, much bigger and the stability level is a little bit higher generally. We have reached a very high level with the twist beam on our other cars but we would not do the multi-link if it was not better! There is more lateral stiffness and you can reduce the slip angle on the tyres - in the comfort mode it's even better because you are softer in a longitudinal direction."
How fast do you have to be going for the downforce to make a difference?
"I think when you drive the Clubsport versus the normal one you will feel the difference above 70mph. The quicker you are the more difference you feel!"
Can you tell us how much downforce there is?
"I know those figures but to be honest we have made lots of comparison tests in different wind tunnels and the wind tunnel at Wolfsburg works differently from other ones, so you get different figures."
Sway Bars
