These guys down here will be better able to assess.
http://www.golfmk7.com/forums/showthread.php?p=541757#post541757
Thank you!
Finally reinstalled the JB4 tonight, only mods as of now are an inlet. Captured two logs tonight, map 2 and a map 6. If y'all have a few minutes, please let me know what you think. Thanks!
map 2: https://datazap.me/u/merc/log-1511401201?log=0&data=1-3-4-5-6-11-18-19-23-25-26-27
map 6: https://datazap.me/u/merc/log-1511401201?log=1&data=1-3-4-5-6-11-18-19-23-25-26-27
map 6 values:
1500 11
2000 12
2500 13
3000 13
3500 15
4000 16
4500 18
5000 19
5500 17
6000 16
6500 15
7000 15
Fuel Open Loop 70
Lowered my boost and added a little E85.
https://datazap.me/u/miked617/93-e85?log=0&data=1-2-4-6-11-14-18-19-25-26&solo=4-6&mark=43
Thanks!! I'm planning to just leave it until I get my downpipe installed then I'll re-log.Looks good.
A couple logs-my first time using datazap. I can’t figure out how to get the parameters to stick, but you should be able to add the applicable ones.
https://datazap.me/u/pingers/4th-gear-thanksgiving?log=0&data=1-2-4-11-14-18-25-26
https://datazap.me/u/pingers/3rd-4th-gear-thanksgiving?log=0&data=1-2-4-11-14-18-25-26
Set boost safety to 27 and fuel open loop to 60. I did get a “3AD2” (Fuel Rail) code on the 3rd to 4th gear pull.
1500 15
2000 16
2500 18
3000 21
3500 23
4000 24
4500 23
5000 21
5500 20
6000 18
6500 17
7000 16
Set FOL to 50.
Thanks Diggs! How do the logs look?
Sehr gut.
Perfect.
Swap these 2
5000 6
5500 6.5
Try it out and report back.
Feels great! Much better than before. I wouldn't mind a tiny bit more aggression, maybe if there is a way to reduce the turbo lag a bit, or get it to hit harder when I downshift into 4th and floor it. Otherwise I'm very happy!
Did a log today.
Have my boost turned down to peak at 22 for the colder weather in mornings.
Didn't get much into 4th... just wasn't happening.
The intercooler appears to be doing a nice job.
https://datazap.me/u/f3joel/log-1511635397?log=0&data=1-4-6-11-14-18&mark=53
