drshark
- Niagara Falls, NY
Ok, finally got around to cropping and re-sizing pics. So, here you go...
Advanti Svelto: 19x8.5 45mm, 21 lbs (-3.5 lbs vs. OEM)
245 35 19 Michelin Pilot Sport 4s
8mm spacers on rear wheels (none on front)
Absolutely no rubbing with the top screws removed on the front wheel well liners. That includes some fairly high acceleration/deceleration corners. As noted last week, one wheel absorbed without damage a serious enough pothole shock to break the OEM tire sidewall. And the PS4s are SO soft and sticky.
I recommend without hesitation!
P.S.: the rear spoiler makes a huge visual difference for not too much money. However, the CF hood is a really an indulgence for the cost -- though you do save 22 lbs, for what it's worth...
