Hi.
As above I have a set of 4 as new only done 80 miles 16 inch vw black steel wheels ideal to fit your own winter tyres. NO TYRES ON THESE JUST THE RIMS.
No damage or marks at all.
Collection preferred unless you want to arrange a courier at cost to yourself or can meet if local..
Boxed £80.
Sheffield
Centre Bore:
57.1
Fixings:
Use OEM Bolts/Nuts
Material:
Steel
Offset (ET):
48
Stud Pattern (PCD):
5x112
Wheel Diameter:
16"
Wheel Width:
6.0"
Regards Neil
Boxed £80.
Sheffield
Centre Bore:
57.1
Fixings:
Use OEM Bolts/Nuts
Material:
Steel
Offset (ET):
48
Stud Pattern (PCD):
5x112
Wheel Diameter:
16"
Wheel Width:
6.0"
Regards Neil
