DMFW on its way out?
ashiun
Toronto, Ontario
Ok... I think my DMFW is officially shitting itself now.
https://youtu.be/cWG31k2Su34
Video of sound here. Chatters and clatters and blatters when I hold clutch at bite point, sound subsides but still can be heard faintly with clutch fully engaged, and no sound when clutch in. Also rattles when I turn off the vehicle, and doesn't if I turn the vehicle off with clutch in.
Still drives fine, doesn't slip, and the only difference it makes is that I can't install my dogbone insert because slipping the clutch causes this rattle to shake my entire car.
0bLiViOuS
Orange County
Ya doesn't sound normal. Possible the TOB and not the actual DMFW would be my other guess, but both suck and might as well put in a new clutch if you do the TOB
ashiun
Toronto, Ontario
https://youtu.be/8kNYvY_RzqI
ok well... I've had my clutch, pressure plate, throw out bearing, AND dual mass flywheel all replaced by the dealer and yet I still hear this chatter. Can someone help me try to identify the source of this sound?
I'm thinking it's the input shaft bearing. Noise is gone when clutch pushed in, noise is there when clutch is let out, and is loudest at bite point.
teemmy
bay area, CA
I think a similar thing happened to my car when I had my clutch replaced. Installer drove the car around the block and realized that he installed something backwards... maybe the pressure plate? Don't really remember, but he reinstalled it again and everything was normal.
ashiun
Toronto, Ontario
Backwards?! Christ. I definitely need to get this checked out again.
ATR
Baltimore
'17 Golf R 6mt
It's not the dual mass flywheel chattering. It's the transmission rattling a bit at idle. My car rattles at idle as well. Sometimes more, other times less.
With a solid flywheel there could be substantially more chatter:
https://youtu.be/05YBmgXpdrM
Common mistake, he likely installed the friction disk backwards.
WhyNotZoidberg?
Chi-Town
2017 GTI, 2015 TDI
When I got my GTI new (100 miles) I had a similar rattle, thought it was the TOB, the dealer replaced the DMFW (from VW instructions), then they ended up replacing the whole gearbox (breaking the plastic tranny locking pin in the process LOL). They did not replace anything in the clutch (PP, disc, TOB), kept my car there for 2 weeks.
Needless to say that dealer will never see my car again :)
