Thanks OP, your install guide helped me to get started.
Finally installed the cornering lights, very nice!
Now I don't have an amber looking cornering that didn't match the xenon headlights.
A coworker had mentioned that I have a nice car but need to change my headlights because they are yellow. I said "no, I have the lighting package", but I quickly figured out that what he saw was the amber cornering.
Anyway, deAutoLED sent me the new adapters at my request. Great follow up customer service, by the way. I would rather call it a retaining clip, but regardless, it works just like the factory retainer.
They also suggested I try the install without the gold resistor that originally came with the kit.
It worked! No codes, and worked perfectly without the gold resistor.
Now for the kicker; the black ballast box fit inside the light assembly, so no cutting of the rubber dust cover was required!
Clean, cool.
I suppose though, that if I had needed the gold resistor, I would have had to make a hole in the dust cover because it gets hot from my understanding, so placing it in the housing would not be a good idea.
Small tip: the bulb is keyed, but has some room for rotational adjustment, so I turned one of them slightly to direct the light to be equal as the other side.
