Recently i swapped my stock suspension for vwr springs and bilstein b8 shocks. Handling is good on dry pavement but when its wet my rear end slides around on road markings / crosswalks which it didnt do before. When swapping i torqued everything to specs and i made sure the bushings were loaded when tightening. I didnt bother with alignment after , but now im thinking it might be caused by that. Maybe the rear toe is out of specs?. Can bad alignment do that?
