FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Marketplace > Vendors Classifieds > Engine and Exhaust
Reply
Thread Tools Display Modes
Old 07-18-2017, 09:18 PM   #375
AtlantaDad
Senior Member
Drives: Night Blue 2016 GTI Autobahn DSG PP LP
Quote:
Originally Posted by BananaSlug View Post
IT CAME TODAY!
Uh oh...GESI cat! Baller alert!
__________________
2016 GTI NB PP LP | Cobb AP w/ MAPerformance Stage 2 | MAPerformance Catted/Resonated DP | AFE drop-in w/ snow guard delete | 034 Dogbone Insert
Thou shalt read this first: http://www.golfmk7.com/forums/showthread.php?t=18297
AtlantaDad is offline   Reply With Quote
Old Yesterday, 12:44 AM   #376
miked617
Senior Member
Drives: 16 VW GTI Autobahn PP,LP,DCC,DSG, JB4, K&N
Now I need a spacer and I'm golden.
miked617 is online now   Reply With Quote
Old Yesterday, 01:00 AM   #377
BananaSlug
Senior Member
BananaSlug's Avatar
Drives: 2016 VW GTI SE DSG
Anyone have issue with the fitment between the midpipe and stock catback? The midpipe side seems really loose. I might have to buy another coupler or whatever it's called.
__________________
2016 CSG VW GTI SE DSG | LP | Johnson Ceramic Tint | Cobb Stage 1 by MAP | 034 Dogbone Insert | IE IC | MAP Downpipe /w GESI cat
Soon: aFe Air Filter | CTS TIP | ED DSG Tune
Future: Eibach Springs and Sway Bars | RSe10/Rse11
BananaSlug is offline   Reply With Quote
Old Yesterday, 01:29 AM   #378
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
Question
Did you move muffler forward?
__________________
JB4 / IE Intercooler / MAP cat+res Downpipe
Diggs24 is offline   Reply With Quote
Old Yesterday, 02:29 AM   #379
miked617
Senior Member
Is anyone heat wrapping their downpipe?
Old Yesterday, 03:01 AM   #380
psychonosspaz
Senior Member
Drives: 2016 White VW GTI SE 6 MT (PP, LP, MMs)
Quote:
Is it proven to help?
__________________
2016 PURE WHITE GTI [LP/MANUAL/PP] [BOOMBA SHIFT ADAPTER] [BFI WEIGHTED KNOB] [BMS INTAKE] [JB4 w/BLUETOOTH] [VWR SPRINGS] [ECS FLUSH KIT] [RSR CLUTCH KIT]
psychonosspaz is offline   Reply With Quote
Old Yesterday, 03:03 AM   #381
BananaSlug
Senior Member
BananaSlug's Avatar
Quote:
I ended up having a friend push the muffler towards the front of the car while I tightened the coupler. I also moved the coupler as close as possible to where the midpipe reduces to 2.5" and that seemed to stop the midpipe from wiggling.
__________________
Old Yesterday, 03:33 AM   #382
miked617
Senior Member
Quote:
In general yes, on the mk7 gti, I don't know.
I have a forge turbo blanket so I was going to install that and also wrap the downpipe. But if it's not worth the effort I certainly won't.
Old Yesterday, 03:42 PM   #383
Boo
Junior Member
Drives: GTI Sport
Got it installed. I have the 17' GTI sports (LSD...)
I followed this video. https://www.youtube.com/watch?v=hTiQ1PEs2eM
I ran into a few issues. One being with the LSD, I couldn't pull the down pipe out by itself. I had to take the heat shield off like they did in the video. My heat shield was different and it used a T30ish star bit and 4 small screws. It's pretty difficult to get them out as I was doing them all by touch and couldn't see how many or where they were.
Once OEM downpipe was out, the MAP downpipe went in easily...
2nd issue, the downpipe didn't fit. I'm not sure why but I was unable to have both the downpipe bolted on and get the vband to the turbo to sit flush. It took hours and with two people but it would not fit. The downpipe, hangers, mount, etc. all looked striaght. When it was bolted flush, there was a 10 degree alignment issue and 1/2 a cm height problem. If looking from rear to front of car, the right side of the hanger hole needed to be expanded by a 1/2 of a cm. So I enlarged the hole to allow the downpipe to sit higher. After that, it went on smoothly. Getting the heat shield back on was a pain and I lost a screw... it's stuck somewhere in the LSD housing/support structure. I was a little disappointed in the fitting but not sure if it was the pipe itself or the GTI Sport model.
Few things I learned, it's a lot easier if your car is farther off the ground. The VBand can appear to be on and not be on elsewhere. To sure to double check both sides of the lip to make sure it's covering the flanges. I also needed to pull the muffler forward and then I tightened the band.
It took like 5 hours and of it, 1.5 of it was dealing with the damn heat shield and 2 more was getting the MAP downpipe to fit and ultimately filed/drilled.
Any questions, let me know.
Boo is offline   Reply With Quote
Old Yesterday, 04:17 PM   #384
king12sky
Senior Member
Drives: 17' GTI, 14' S4
That is correct if you have the LSD/PP. When i had my awe downpipe i had to take out the heatshield to install as well. I didnt put it back on after as it was a PITA.
king12sky is offline   Reply With Quote
Old Yesterday, 04:20 PM   #385
AtlantaDad
Senior Member
Also have the PP. I didn't remove the heat shield because it didn't look like the one in the shopdap video, and I couldn't see the bolts. It took forever and lots of twisting/finesse, but I did eventually get the oem pipe out. So it can be done.
__________________
Old Yesterday, 05:00 PM   #386
Boo
Junior Member
Drives: GTI Sport
Now that I know how to get them in/out and if I was standing, I might be able to do it. At least on my car, the heat shield ate up a lot of space for rotating. Just an FYI if anyone spends more than 30 minutes trying to get it out, taking the heat shield off makes it much easier.
Old Yesterday, 05:11 PM   #387
Diggs24
Senior Member
Diggs24's Avatar
I don't have PP, but I can't imagine VW gave us different downpipes, so the hangar that attaches to the block should be the same, yes? It looks so in all the videos. All the install videos I watched had PP and the steps except the heat shield removal were identical to what I did.
I also had a hard time getting the DP to mate to the turbo after I slid it onto the 2 hangar bolts. It was sooooooooooooooooooooooooooo much easier if you remove the TOP NUT from the passenger side of the hangar (so 3 total nuts removed). It's straight down next to the suspension. All did was put a 18" extension on my ratchet. Easy off. Then the hanger can move around a bit while also supporting the DP so you can get it to mate up. THEN you can mate it up to the turbo with ease. Put the vband on about halfwayish to keep it in place, THEN put that top nut back on the hanger, THEN go put the 2 nuts on the hangar under the car, then move on to the bracket with the rubber thingies and bolt that down. And just keep going back. At the end you come back to the turbo and finish off the vband and plug in the o2 sensor.
This guy shows that 3rd nut and how everything was so much simpler after he removed it.
https://www.youtube.com/watch?v=RMUsbyJI550
Start at 9 minutes.
__________________
Old Yesterday, 07:01 PM   #388
Boo
Junior Member
Drives: GTI Sport
I would also assume the down pipes would be the same. My main issue was that it wasn't flush with a gap on the front side. Even with moving that 3rd bolt (maybe I should have played with it more, I didn't know that was a thing I should have been doing), I still couldn't get it to line up correctly. I'm sure better people than me could have done it but I was already deviating from the expected amount of things to touch
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
