Old 09-21-2014, 09:33 PM   #69
mk7norway
Drives: Golf VII, 2.0TDI, 4Motion, Highline
Originally Posted by Jota Mendes View Post
Check this. Everything you want is there.
http://www.golfmk7.com/forums/showthread.php?t=4862
thanks mate!! awesome!! =)
mk7norway is offline   Reply With Quote
Old 09-22-2014, 07:35 PM   #70
Jota Mendes
Jota Mendes's Avatar
Drives: MK7
No problem, if you get the headlights post some pictures for us here.
Be patient with my English please.
Jota Mendes is offline   Reply With Quote
Old 09-22-2014, 10:27 PM   #71
mk7norway
Yes Sir!! I will
Is there anyone that bought these headlights that can take a picture from the inside of your car at night, and outside?? :-)
Old 09-23-2014, 05:05 AM   #72
Jota Mendes
Drives: MK7
Yes Sir!! I will
Thanks mate.
x2
Sent from my GT-S7500 using Tapatalk 2
Old 09-28-2014, 04:25 AM   #73
ZrC
Drives: 2015 GTI, 2008 Rabbit
thanks mate... so the only thing I need to buy is the D3S xenon bulb??
The low beam is xenon with 6000k??
but the highbeam is H7 halogen?
Could you write what is included in the price?
6000k is terrible blue. You want OEM which is 4200k and 5000k max which still has a little more blue than OEM.
ZrC is offline   Reply With Quote
Old 11-11-2014, 05:23 PM   #74
firot
Drives: golf mk 7
can i use these with my original halogen bulbs without any external accessories?
if so, will my original bulbs run behind the lenses without any visiblity loss?
firot is offline   Reply With Quote
Old 11-12-2014, 08:14 AM   #75
edward@becautoparts.com
Drives: VW Jetta, Volvo V70
You can use regular H7 bulbs, and they will fit in there without the need of any adapters, etc.
Depending on the the brightness of the bulb, you will see alot better than the stock lights, but not as bright as HID bulbs. The beam pattern will be the same as with the HID bulbs as the pattern is dependent on the projector itself.
edward@becautoparts.com is offline   Reply With Quote
Old 11-17-2014, 02:04 AM   #76
101D12
Drives: 2015 GTI CSG
Originally Posted by JimmyV83 View Post
Hello everyone,
I recently purchased Eds replica lights and wanted to post a review for everyone.
First, to begin, I have the MK7 GTI and was not a fan of the halogen lights or the projectors with the red light running through it. I heard Ed was the go to guy for replicas and after contacting him, he had a pair in stock for me.
I received the lights (with the adapter) and HID kit in perfect condition thanks to Eds excellent packing and immediately you could tell that they we're built with better quality then your average aftermarket lights. The plastic was nice and hard and the inside of the lights do no look cheap as they usually do with aftermarket lights.
The installation was very simple, all you have to do is remove some bolts on the bumper, remove the grill, and remove the bolts holding the lights. They fit in very nicely with no gaps between the curves.
Once I powered them on, you immediately noticed the LEDs we're nice and bright and the HIDs we're leveled straight. I also did NOT have to do any coding and I did NOT have any bulb out errors which made the lights that much better. I tested all the signal lights, side markers, DRLs, etc and all worked without issues. One cool thing I noticed was that the LEDs shut off on the side of the signal light as they are supposed to be. I am not sure if the DRLs are supposed to dim or not when the headlights are on, but they do not which I prefer since I like bright LEDs.
All in all, I am VERY satisfied with the lights and their quality and make. They work perfectly as intended and they really bring the car together. I have also attached pictures for everyone!
Get yours before he runs out!
Sent from my HTC One_M8 using Tapatalk
Hey Jimmy,
I'm currently installing the headlights and I have some questions.
Firstly, where do I connect the red cable running from both housings to the fuse?
Also, it seems the new headlights came with additional harnesses.
The way I set them up (I did not see instructions on the diagram for them) was:
new headlights <-> new harness (adapter?) <-> original harness <----
as opposed to how it was before:
old headlights <-> original harness <----
Is this correct? Or should I have simply gone straight from the new headlights to the original harness (but then what are the new harnesses for?)?
101D12 is offline   Reply With Quote
Old 11-17-2014, 04:49 PM   #77
RAY_GTI
Drives: 2015 GTI, 2011 E90 M3
I got my replicas last Friday but haven't installed them yet. I looked at my kit and the fuse harness with the red cable and a ring connector at the end connects to the positive terminal of the batt.
Originally Posted by 101D12 View Post
Hey Jimmy,
RAY_GTI is offline   Reply With Quote
Old 11-18-2014, 12:39 AM   #78
Hey Jimmy,
If you ordered the lights from me, there is a wiring diagram on how to connect it all up on the HID Ballast box.
Old 11-18-2014, 12:54 AM   #79
101D12
If I'm reading the wiring diagram correctly, I'm assuming the red connecter should be connected to the battery at the point shown?
triple edit:
To answer my own question, YES - in my case I cut a piece of the ring connector off so I could snugly fit it against the positive terminal.
Old 12-20-2014, 11:13 PM   #80
ohsnapzombies
Drives: GTI
triple edit:
what? I don't recall having to connect it to the battery on my MK6 w/eds lights.
ohsnapzombies is offline   Reply With Quote
Old 07-20-2015, 06:37 PM   #81
manev
Drives: 12' CC
I was told that a version with the red stripe will be out by early fall. Once they are ready I will post more info. They will be manufactured by the same company that makes these Golf R reps.
The GTI reps sold by Winpower, I would not want to touch...
Ed! Request a color match stripe!! Like black or white or the blue)
manev is offline   Reply With Quote
Old 07-26-2015, 05:35 PM   #82
The factory will only do a large order if you want a color match stripe, however blue as on the e-Golf is available if anyone wanted that.
Old 07-30-2015, 10:22 AM   #83
toronto
Drives: MK7 1.8 TSI
A dumb question guys. the product is only for cars equipped with factory halogen lights, im not sure what my trendline has.
toronto is offline   Reply With Quote
Old 07-30-2015, 05:10 PM   #84
mk7norway
Trendline will not be deliverd with the lights that Ed is selling If you have a Trendline, you have halogen lights! :-)
Old 07-31-2015, 06:14 AM   #85
toronto
Drives: MK7 1.8 TSI
wow I have halogens. I thought Trendline's have regular cheap headlights. I didn't know they are also halogen thanks for your answer my friend
