Old 10-31-2017, 05:03 PM   #1
lumberjackzac
Drives: VW GTI '16
Trunk LEDs for $20
I decided to take on some DIY work and order LEDs from Amazon. They are so cheap that if it didn't work I wouldn't bother returning.
Basically I just started from over by the OEM trunk light and worked my way over with cheap thermostat wire and plastics glue.( Be particular about the glue. Super glue will permanently burn the plastic) Super easy to remove if I wanted. I bent the wire around each end of the OEM trunk light assembly and viola.
The lights around the bottom edge have been removed they would not stay stuck with the tacky plastics glue I used. May try again in spring
'16 GTI S- DSG LP
Revo mounts Engine, Trans, Dogbone| DV+|All season DWS Conti|Allfit Lip|Escort Max360|Thinkware F770|
lumberjackzac is offline   Reply With Quote
Old 11-01-2017, 03:40 AM   #2
nype
nype's Avatar
Drives: 2016 GTI Performance - DSG - Carbon Grey w/Leather
Amazingly bright. Id imagine you will attract a decent amount of insects!
nype is offline   Reply With Quote
Old 11-01-2017, 03:48 AM   #3
lumberjackzac
Drives: VW GTI '16
They way I had the lights angled is away from your eyes because it's blinding and to minimize bugs. Along the ridges that face toward front of car. Not had any bugs
Sent from my SM-G935V using Tapatalk
'16 GTI S- DSG LP
Old 11-01-2017, 07:13 PM   #4
darth_furious
Drives: 2015 gsw tdi s
looks nice and bright. The only thing I did differently on my old VW was a 3000K strip instead of a 6000K strip. I prefer a yellow look instead of bright bluish. I would recommend looking into 3000K if you don't mind a little yellow. It is easier on the eyes late at night.
darth_furious is offline   Reply With Quote
Old 11-03-2017, 02:44 PM   #5
RISC_Taker
Drives: 2017 Golf TSI Wolfsburg 4dr (1.8L 4cyl Turbo)
Can you link to the lights you ordered? That looks great! Thanks very much.
RISC_Taker is offline   Reply With Quote
Old 11-06-2017, 08:20 AM   #6
lumberjackzac
Drives: VW GTI '16
$9.99 you can cut them.
FAVOLCANO High Density Cool White IP65 Waterproof Led Light Strip, LED Tape ,SMD 3528, 600 LEDs 5 Meter or 16.4 Feet LED Strip 120 Leds/M Multifunction
https://www.amazon.com/dp/B012FFZANO..._ogIs3avPDt6Tv
Plus glue and wire,etc
'16 GTI S- DSG LP
Old 11-08-2017, 05:10 PM   #7
volks6
Drives: VW
Why do you need to have such bright trunk lights? Are you cooking dinner in you trunk?
What's the point?
I put groceries and other crap in there and when I get home I take them out. It's not like they get lost in some black hole.
Seems like a fix for something not needing a fix or even attention.
You, volks6, are a Troll because you ask hard questions about our superior products
To quote the great TheGreekFreak "Save the hate for the posers" and "Triggered yo!"
volks6 is offline   Reply With Quote
Old 11-08-2017, 07:01 PM   #8
imthanick_a
imthanick_a's Avatar
Drives: 2016 MK7 GTI SE w/ PP, DCC, and Lighting
What's the point?
Come back to this thread when you need to change a flat in the dark
2016 Tornado Red GTI SE with PP, LP, and DCC
Neuspeed P-Flo, 034 Dogbone Mount Insert, JB1, ECS Tuning Stainless Steel Rear Brake Lines, Fast FC04 Bronze with Sumitomo HTR Z III
imthanick_a is offline   Reply With Quote
Old 11-08-2017, 07:38 PM   #9
darth_furious
What's the point?
I bet the picture makes it look brighter than in real life. At least that's how my lights are. you need to do negative exposure compensation on your phone camera because the surroundings are pretty lit up and grainy and your oem yellow light looks way brighter than it should.
When you put groceries and it blocks the OEM light, it gets pretty dark I'm guessing. If you have light all along the edge, you can put things in there and if it blocks 1/2 the edge, it will still be bright enough.
Next, if you don't want it that bright, you don't have to install it. There may be some people who want it that bright and have specific use cases where it would be handy. This post would be for them. Having done something similar, I understand it's a little overkill but there have been times I was glad i had it
Old 11-08-2017, 07:48 PM   #10
NeedSleep
NeedSleep's Avatar
Drives: 2017 GTI Sport DSG
Or even having a trunk full of large items. During a recent Southern California fire, we loaded luggages and small bags in my car in case we needed to evacuate. Our luggages and small bags are all either dark blue or black. When I was loading the car at night while trying to find empty spaces to do some tetris work, I couldn't see anything in 3/4 of the trunk.
Sure, needing that much light isn't always a necessity, but once you actually need it, it'd be great to have what the OP did.
Sent from my SM-G930T using Tapatalk
NeedSleep is offline   Reply With Quote
Old 11-09-2017, 03:44 AM   #11
volks6
Drives: VW
That's why they make these things called flashlights.
I still don't get having the equivalent of the sun in my hatch.
Old 11-09-2017, 03:52 AM   #12
lumberjackzac
Drives: VW GTI '16
It's a bit overexposed. Agreed
'16 GTI S- DSG LP
Old 11-09-2017, 03:53 AM   #13
lumberjackzac
Drives: VW GTI '16
What's the point?
I keep files on my clients and cases in there. Like 12 point font. It'd be impossible to find anything in there after dark even with a flashlight. Road warrior sales agent
'16 GTI S- DSG LP
Old 11-09-2017, 04:02 AM   #14
imthanick_a
To each their own. I prefer having both hands to work with instead of trying to balance a flashlight on my shoulder, but if you enjoy fumbling with an external light when you could have a bright, cheap option that is always there without excess interaction, then that's your perogative.
Sent from my SM-G930V using Tapatalk
Old 11-09-2017, 10:32 AM   #15
darth_furious
Not to hijack, but here is my install. It's nice and bright and under $15. It's really bright but not blinding. Maybe volks6 will approve of this one. Probably not
https://www.amazon.com/YITAMOTOR-Day...dp/B018G5MY5O/
Here it is with the cargo cover pulled back
Side view:
Close up of install:
I did manual white balance on my phone (cloudy wb so 5000k. Not 6000k but closer). My kids wanted to play inside. You can get a sense of color and brightness. The interior lights are definitely warmer
Old 11-09-2017, 05:47 PM   #16
volks6
Drives: VW
VW didn't tell you to use 12pt font size. It's also not a file cabinet. Go paperless and save a tree for the future.
There I fixed it for you.
Old 11-09-2017, 05:47 PM   #17
volks6
Drives: VW
Those poor kids need sunscreen on. Bad parenting right there.
