Old 10-26-2017, 11:11 PM   #1
Chogokin
Chogokin's Avatar
Drives: GTI Sport/MK6 JSW/Banshee Spitfire/Cervelo S2
Rear fog only Euro switch?
Since I have a Sport with no front fogs and I'm planning on getting some Euro (Mk7) tails. Is there a switch with no front fog and only the rear fog position?
I've had the rear fogs wired up on my Mk3, Corrado, and they came stock on my S4. Its something I've always liked on my VWs. Is there a way to wire up the rear fog with the stock harness? At this point, I'm not sure I want to run the aftermarket harness. I want to keep everything on the car completely reversible.
Thx.
NM, found it on DAP's site. Costs quite a bit more than the "Euro" switches!
https://shopdap.com/5g0-941-431-bg-wzu.html
e-Acca also has it.
http://www.e-acca.com/index.php?page...orderBy=gruppa
Thanks Gabriel
Auto only
http://www.bold-sport.com/store/inde...product_id=349
Chogokin is offline   Reply With Quote
Old 10-26-2017, 11:51 PM   #2
chiefhiawatha
Drives: 2017 GTI manual
How did you end up without front fogs?
chiefhiawatha is offline   Reply With Quote
Old 10-27-2017, 12:03 AM   #3
BxGTI
BxGTI's Avatar
Drives: 2015 VW MK7 GTI, 2017 Audi A4 PP S Line2.0T
The sport does not come with fogs
2015 Tornado Red GTI MK7
BxGTI is online now   Reply With Quote
Old 10-27-2017, 12:20 AM   #4
Derushi
Drives: PP/LP 6MT
I'm pretty sure there's no way to run rear fogs without having some sort of harness in place. You can plug and play the LED tail lights but Amber turn signals and rear fogs aren't functional without the proper harness and coding.
Also you might want to try the Golf R Euro light switch. They don't have front fogs, and only has rear fog (in countries where LED tail lights are present). Though I'm not sure if it works for the GTI.
Maybe you can source a cheap one from Aliexpress or something. Not sure if this one works for the MK7... https://www.aliexpress.com/item/Chro...322193644.html
Carbon Steel
JB4 // APR Intercooler // Clubsport S Muffler - MAPerformance Catted+Resonated Downpipe - APR Front Muffler (Resonator)
Derushi is offline   Reply With Quote
Old 10-27-2017, 01:01 AM   #5
Chogokin
Chogokin's Avatar
Yeah...I figured you probably can't wire up the rear fog just by running a wire like on the older cars.
I looked up the switch for the Golf R. It looks like it just has the Auto function added onto the switch.
Old cars are so much simpler to mod. Lol...all I had to do on my Mk3 was run a wire from the switch to the taillight.
Thanks for the reply!
Old 10-27-2017, 02:38 AM   #6
Wastegate13
Wastegate13's Avatar
Drives: 2015 GTI SE
The AliExpress switch can be coded to operate a rear fog when the lights themselves are wired properly. I am running one now. I once asked if it was possible to control a rear fog using the stock switch since I deleted my fog lights and I think someone said I could but I never got around to trying it out.
Wastegate13 is offline   Reply With Quote
Old 10-28-2017, 01:56 AM   #7
BillTchr
Drives: 2017 Alltrack S 6MT
Have you run across this thread on VWVortex? http://forums.vwvortex.com/showthrea...Light-Retrofit
It's actually not that hard to get the rear fog going, as long as you have access to a VCDS cable or an OBD11... Basically, you switch the reverse light wire in the plug from the car on the driver's side, recode that wire in the BCM to be a rear fog light, and then bridge a wire for the driver's side reverse light over from the passenger side reverse wire. You also need to use LED bulbs in the reverse spots so 2 incandescent bulbs don't freak the BCM out by drawing too much current.
Hope this helps!
BillTchr is offline   Reply With Quote
Old 11-03-2017, 01:13 AM   #8
Chogokin
Chogokin's Avatar
Hope this helps!
I did not see that before. Too bad the pics are gone.
Thanks!
Old 11-03-2017, 04:41 PM   #9
kubo777
Drives: MK7 GTI
Thanks!
Use Chrome with Photobucket Hotlink fix to see the pics.
https://chrome.google.com/webstore/d...alioapbifiaedg
kubo777 is offline   Reply With Quote
Old 11-17-2017, 03:36 PM   #10
comingabriel
Drives: MK7 R
Your headlight harness may have the rear fog wire running to bcm, but you have to run a wire from the bcm to rear.
Plenty of write-ups if you google.
comingabriel is offline   Reply With Quote
Old 11-17-2017, 03:57 PM   #11
sprinks
Drives: GTI Mk7
You beautiful person.
wheelwell & GTI mk7 journal
Old 11-17-2017, 08:44 PM   #12
daujin229
Drives: 2016 GTI DSG
Finally I can do this mod. Perfect since winter is coming
daujin229 is offline   Reply With Quote
Old 11-21-2017, 08:41 AM   #13
Chogokin
Chogokin's Avatar
Wow...thanks!
Old 11-22-2017, 04:31 AM   #14
Logistician
Drives: MK7 GTI SE
Is there a way to do this if you have fog lights and non-LED tails and keep them functional?
Logistician is offline   Reply With Quote
Old 11-22-2017, 02:41 PM   #15
Wastegate13
Drives: 2015 GTI SE
Just buy the AliExpress switch, wire the rear fog per the instructions and then code the BCM to know you have a rear fog installed.
Old 12-01-2017, 06:55 AM   #16
Chogokin
Chogokin's Avatar
So I ended up getting the switch from Paul@DAP. Installed it and my lights seem to function fine. I'm using it without the harness for the Euro tails so no coding changes. I'll be installing the harness next week.
Did a random scan and found this. Is it because I unplugged the switch to switch out my switch?
Sent from my Mi A1 using Tapatalk
Old 12-01-2017, 07:30 AM   #17
nype
nype's Avatar
Drives: 2016 GTI Performance - DSG - Carbon Grey w/Leather
Which channel is powering the rear fog?
If LeD bulb, you need to set this channel accordingly. We
nype is offline   Reply With Quote
