Old 10-23-2017, 10:58 PM   #511
XoneDB4
Drives: Mk7.5 GTI PP DSG
Has anyone successfully ordered the DSG steering wheel in the UK/EU? My dealer says all the part numbers come up labelled as leather and they’re on back order so if I order the wrong one I still have to pay for it...
Really want that alcantara...
XoneDB4 is offline   Reply With Quote
Old 10-24-2017, 01:13 AM   #512
Derushi
Drives: PP/LP 6MT
Originally Posted by DU30 View Post
Hi mates! I am new to this forum but i have been reading about this thread for a while. I own a gti40years here in Sydney and i want to change my side sticker from “40 years” to “clubsport”. Do you guys know where can i get one?
https://www.kunzmann.de/shop/en/exte...volkswagen.htm
Might be cheaper to have it custom made at a local shop.
Carbon Steel
JB4 // APR Intercooler // Clubsport S Muffler - MAPerformance Catted+Resonated Downpipe - APR Front Muffler (Resonator)
Derushi is offline   Reply With Quote
Old 10-25-2017, 09:12 AM   #513
replicate
Drives: Mk7 GTI Clubsport
The 40 Years sticker does look a bit crap. I’m pretty sure one of the guys on here ordered the Clubsport sticker. It’s in this thread somewhere. Whole thread is worth a read anyway.
replicate is offline   Reply With Quote
Old 10-25-2017, 12:42 PM   #514
XoneDB4
Just a follow up on the Clubsport steering wheel - I was quoted £717 without fitting from the dealer and I would have had to pay up front with no guarantee it would actually fit my car.
Probably going to go for a custom job...
Old 10-26-2017, 07:21 AM   #515
replicate
It fits, lots have done it. Just buy it from cars245 or the other one and fit it yourself if you can.
Old 10-27-2017, 11:47 AM   #516
XoneDB4
Is there a guide on how to do it somewhere? I’m fine doing most small DIY bits myself but slightly worried about the airbag - also doesn’t it need coding?
Old 10-27-2017, 11:33 PM   #517
replicate
Reach out to the guy in this post. Says it took him 30 mins.
http://www.golfmk7.com/forums/showpo...postcount=4191
Old 10-28-2017, 12:15 AM   #518
BxGTI
BxGTI's Avatar
Drives: 2015 VW MK7 GTI, 2017 Audi A4 PP S Line2.0T
Here
https://youtu.be/UkYO729io0o
2015 Tornado Red GTI MK7
BxGTI is online now   Reply With Quote
Old 10-29-2017, 07:09 PM   #519
XoneDB4
Thanks both
Old 10-30-2017, 10:15 PM   #520
ecsta
Drives: 2017 R
Originally Posted by BxGTI View Post
Here
I like how at the end he installed it completely crooked lol.
Anyone know how much labor were looking at if i wanted to pay the stealership to swap the wheel+airbag+trim?
ecsta is offline   Reply With Quote
Old 11-04-2017, 07:23 AM   #521
LeGti
Drives: 2015 PP Gti
Originally Posted by EB2429 View Post
Clubsport part numbers
Sway Bars
5Q0411303N front anti roll bar (sway bar) 24mmx 3.8mm (same as GTI PP)
5Q0511305AT Rear anti roll bar (sway bar) 21.7 x 3mm (same as GTI PP)
FRONT SPRINGS 5Q0411105GD (GTi PP 5Q0411105CC)
FRONT SHOCK 5Q0413031FN (same as GTI PP)
STRUT MOUNT 5Q0412331D (same as GTI PP)
BUMPSTOP 1K0412303F (same as GTI PP)
REAR SPRING 5Q0511115HL (GTi PP 5Q0511115HM)
REAR SHOCK 5Q0513029GL (same as GTI PP)
So as you can see (unfortunately) virtually no change between the Gti and Clubsport, TBH i am a little disappointed as i was expecting from the press releases about the cars that VW had reworked the suspension and uprated it with perhaps dampers and swar bar changes, Have the journos with the all inclusive VW paid trips to Portimao circuit just been describing 10% stiffer springs??
Guys, Teck', Breakin': Thank you so much for the wealth of information here!!
Last time I saw this thread was over a year ago, before becoming suddenly ill. Two months after my last post on this thread I received a heart transplant. 15 days after the surgery I drove the VW home... Very lucky, immensely grateful :-)
I have not read to the end of this thread yet, but I'm hoping you found out that the DCC control module has a different part #, maybe the VAQ's as well.
That could explain the difference in behavior from just a spring change ;-)
Fingers crossed!!
Chassis: DCC / DG springs / UBQ, XBQ / SuperPro SupAloy A-arms, rear bushes, sway bars, engine & trans mounts. Transmish': Torque Solutions cable ends & bracket bushes / APR ss / delay delete & braided clutch line & spring delete / WotBox. Engine: / JB1 / Fluidamper / R600 full / Forge DV / Wagner IC / BCS turbo-back.
Last edited by LeGti; 11-04-2017 at 07:30 AM. Reason: They gave me the heart of a blonde...
LeGti is offline   Reply With Quote
Old 11-04-2017, 04:32 PM   #522
ucfquattroguy
Drives: 2017 GTi
The VAQ hardware is the same p/n along with the control module. The only difference seems to be the "Acoustic wiring logic" adaptation setting in the Diff Lock module. It's been confirmed the PP and CS share the same setting. It's believed only the CSS has unique adaptation value "increased traction" if you're reading from a PP/CS car.
ucfquattroguy is offline   Reply With Quote
Old 11-04-2017, 08:43 PM   #523
The BW FXD is used almost "as is" in the Seat Leon Cupra R TCR & MK7 Golf GTI TCR...apparently the only difference is the external case...
This might be because the unit has externally adjustable preload....with a recommended setting in the range of 50nm to 100nm....reading from the Seat TCR owners manual..
My Build:- Click Here
Old 11-05-2017, 05:49 PM   #524
LeGti
Drives: 2015 PP Gti
Hi, thanks for the info. Seemed to me the part numbers for the VAQ and DCC control module boxes had different part numbers, one for the Gti PP and another for the CSS...? I'll go back and check.
However, on my 2015 ROW (France in my case) manual transmission Gti PP, there is an "Increased traction" setting, which I enabled with VCDS. I'll see if I can take a screen capture for you.
Old 11-05-2017, 05:52 PM   #525
LeGti
Drives: 2015 PP Gti
Wow, thanks for that!
Old 11-05-2017, 07:07 PM   #526
No problems...
Old 11-06-2017, 04:34 AM   #527
replicate
Thats the same Increased Traction setting that ucfquattroguy is talking about.
