Which glow plug?
Golf457
Guilford, UK
I have an error code saying my cylinder 4 glow plug needs replacing. I expected it to be an easy replacement but apparently there are two types, one with a pressure sensor and one without. Euro Car Parts asked me "Does your vehicle come with a pressure sensor". How would I know?
St. Olaf
Some UK fellows use to drive Diesels.
I don't doubt he does know about the difference between spark plugs and glow plugs.
Sorry, I can't help too.
Golf457
Guilford, UK
Yep, I know the difference.
I've just never come across glow plugs with pressure sensors.
Any way, I've ordered the standard type and then I'll see if it looks like the one I'm replacing.
Cheers
c31561
East Coast, USA
2017 GTI Sport
If you are replacing on a VW TDI, yes, the glow plugs have a pressure sensor.
Golf457
Guilford, UK
Really? I'd come to the conclusion mine didn't. They cost about £90 as opposed to £15 without the sensor (UK). My car is BlueMotion perhaps that makes a difference. When it arrives I'll compare it.
Thanks.
c31561
East Coast, USA
2017 GTI Sport
Mine was the 2.0 TDI "Clean Diesel" that raised such a stink. I had to replace one of the glow plugs once, which had a cylinder pressure sensor. It was $100 USD each, so rather painful for a single sensor.
But knowing VW, it will have the pressure sensor. If you have VCDS, you could go in and look to see if there are cylinder pressure readings.
-Dutch-
RI
Ditto, I had two go out. They worked fine but were giving pressure readings that were out of bounds so it threw a code. I found replacements for around $75 each, looks like there's a couple of complete sets on ebay for $119 right now.
http://www.ebay.com/itm/like/162566589496?chn=ps&dispItem=1
Gawernator
Fremont, CA
Golf457
Guilford, UK
Here's my VCDS fault. No mention of pressure so fingers crossed I'm ok with the standard type.
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110012034505092000
1 Fault Found:
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [237] - Electrical Fault
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 60178 km
Date: 2017.09.14
Time: 07:31:16
Engine speed: 964.50 /min
Normed load value: 32.2 %
Vehicle speed: 0 km/h
Coolant temperature: 13 °C
Intake air temperature: 12 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.900 V
Unlearning counter according OBD: 40
Electric auxiliary heater: shut-off conditions-Bit 0: 0
Electric auxiliary heater: shut-off conditions-Bit 8: 130
Electric auxiliary heater: relay activation-Bit 0: 0
Preheat time: 1700 ms
Glow status-Bit 0: 0
Glow status-Bit 8: 0
Glow cycles above temperature threshold-Bit 0: 0
Glow cycles above temperature threshold-Bit 8: 7
Glow cycles below temperature threshold-Bit 0: 0
Glow cycles below temperature threshold-Bit 8: 1
Extern.temp.sens.1 bank 1: raw value: 9.5 °C
Readiness: 1 1 0 0 0
Golf457
Guilford, UK
Ha ha - stupid car was having a laugh at me. Turns out it still gives the error but has only just told me 3 days later.
I've swapped over two plugs to see if the error moves cylinders.
Golf457
Guilford, UK
Doh
Ok stupid me. I thought cylinder 4 was on the right and that's true but I'd been changing cylinder 3! Not realising 4 was further over behind the wiring harness.
Should be fine now.
