The F90000274 and F90000267 are mechanically the same pump.* The only difference between the two is the pressure relief valve built into the pump that sits right under the wiring where it attaches to the pump. This difference allows the F90000274 to be able to run in higher pressure applications without running into pressure relief issues.*
We offer the kit with both F90000274 and F90000267 depending on inventory levels with Walbro either pump will work fine for the car.* We have more experience and more pump options for this car than any other supplier on the market and actually supply products to VTT.
We have dual pump systems, line sets, pressure regulators, etc for this car that are not available on website but we are currently selling in limited volume and have been tested and used by United Motorsports and others.
Regardless of what anyone tell you, you do need flash changes in the ECU or you will fry the control module end of story that is why others did the Walbro 305 and not the 450 in the first place.*
We have 200 F90000274 coming in next week so if you prefer your kit with this pump that is not a problem they are the same pump other than pressure release valve and cost the same for us to buy.
Best regards,
PR Sales Team
