TheMaOdy66
- Germany
Define 'fading'.Don't ix up with fading and boiling fluid. Fading is caused
by overheating pads, which emit gasses when too hot.
Nothing to do with brake fluid. For that reason you can't
combat brake fade with better fluid. You need improved
pads and better ventilation.
It's a good idea to use higher rated fluid to avoid it from
boiling though, which is even more horrible than fading pads.
The fading I mean (pedal getting longer, breaking point more and more undefinable) ist definitely to be fought by stainless lines and brake fluid. ATE Type 200 (which is the same as the Super Blue Racing except color) is always good enough. Take it and please use stainless lines as well and you will not think you use the same break as before.
And yes, ventilation is a very good idea, but first you got to upgrade the rest. Lines, fluid and pads. Discs as well if the other things are not enough. And then it's a question of speed if you need venilation.
To give an example:
On The Ring you can use the OEM .:R-brakes up to a laptime level of around 9:00 [BtG]. If you want to enter speeds up to 8:30, you got to upgrade lines, fluid, pads, discs. And it works well. If you want to go faster than 8:30 you definititely need a BBK on the long term. And additional ventilation if your aim is to go under 8:00.
So, you see, as long as we don't know which speed the OP is able/willing to go, we can't give serious tips. But what always works (against fading) is the upgrade of lines, fluid and pads.
@Goingherenowfast: If there is only the choice you mentioned above, take the hawks. But everything is better than the YellowStuff.
