MAPerformance1
MAPerformance
- Minnesota
- MK7 GTI Sport
Please log the following:
AFR (AFR)
AFR Set Point (afr)
Accel Pedal Position (%)
Air Mass Intake Manifold Per Stroke (mg/stk)
Air Mass Intake Manifold Set Point (gs)
Air Mass Intake Manifold kgh (gs)
Air Mass Limit Per Stroke Turbo (gs)
Air Mass Per Stroke Set Point (mg/stk)
Driver Requested Torque (ft-lb)
EGT Upstream Turbo (F)
Engine Speed (rpm)
Exhaust Pressure Flow Factor (-)
IAT (F)
Ignition Timing Final (Degrees)
Intake Pressure Flow Factor (-)
Knock Retard Cylinder 1 (Degrees)
Knock Retard Cylinder 2 (Degrees)
Knock Retard Cylinder 3 (Degrees)
Knock Retard Cylinder 4 (Degrees)
Mass Flow Limit for Torque Intervention 1 (mg/stk)
Mass Flow Limit for Torque Intervention 2 (mg/stk)
Maximum Torque Overheating Protection (ft-lb)
PUT Set Point (psi)
Pressure Upstream Throttle (psi)
Rail Pressure Actual
Rail Pressure Desired
Relative Engine Load (%)
Relative Load (%)
STFT
TPS (TPS)
Torque Actual (ft-lb)
Torque Indicated Basic (ft-lb)
Torque Limit Turbo Protection (ft-lb)
Torque Limitation Source (-)
Torque Maximum Engine (ft-lb)
Torque Value for Air Mass Set Point (ft-lb)
Torque Reference (ft-lb)
Torque Reference Maximum (ft-lb)
Torque at Clutch (ft-lb)
Turbine Actuator Base Value (%)
Turbine Actuator Final Value (%)
Turbine Actuator Integral (%)
Turbine Actuator Proportional (%)
Turbo Shaft Speed RPM
Valve Lift State (-)
Wastegate Mass Flow SP (g/s)
AFR (AFR)
AFR Set Point (afr)
Engine Speed (rpm)
IAT (F)
PUT Set Point (psi)
Relative Load (%)
STFT
TPS (TPS)
will do. what parameters should I log?
