johng.wissig
When I switch from all season Bridgestone to summer S4 pole positions , same size, my mpg drops about 3-4 mpg. Same air pressure.
Assuming your Golf came with low rolling resistance tires like mine I'm surprised it wasn't a larger mpg hit. I used to average 40+ at 70-75 now it's 35-37 at 70-75.
Not sure if you guys know but you can adjust MFD MPG calculation via OBDII. Mine has been adjusted and now is within 0.5 MPG vs Fuelly or spot on.
Sent from my SAMSUNG-SM-G890A using Tapatalk
never mind. Think I found it. Will be testing today
https://www.audiworld.com/forums/a6...4/adjusting-fuel-consumption-vag-com-2857893/
#2
snagitseven's Avatarsnagitseven , 12-03-2013 08:52 PM
Here you go:
Correct Fuel consumption in DIS (C7): (Revised)
[17-Instruments]
[Coding - 07] > [Adaptation - 10]
Scroll down about 20 items in the drop down list until you see something like fuel consumption adaptation - change the value from 100 to higher or lower:
Example - if your DIS is consistently off by 7% to your actual calculated mpg:
You RAISE the number to the percentage if DIS is OVER reporting mpg (i.e. 107)
You LOWER the number to the percentage if DIS is UNDER reporting mpg (i.e. 93)
Edit: this is the right adaptation description for our cars
Display correction of consumption and operating range, gas
