sprinks
- United States
no sources for that to date.
Should be 5G3863711 KEJ. Not 100% sure but 99%
I like how at the end he installed it completely crooked lol.
Anyone know how much labor were looking at if i wanted to pay the stealership to swap the wheel+airbag+trim?
Hi does anyone know the part number for the clubsport gloss black side skirt to fit a 5 door? And can you take off the original GTi Matt ones and replace with a gloss ones from a club sport or do you need extra fittings ? Thanks Neil
Do you know the spring rates?Been reviewing parts numbers for springs.
I know we tracked down the CSS front springs previously in this thread, but i don't think we found the rears (or at least posted it here). 5Q0411105JF for fronts and it appears that the rears are 5Q0511115HL; slight difference from the GTI PP as 5Q0511115HM.
I suspect these are of course the euro spring rates we're talking about as the NAR PP Springs appear to be 5Q0511115FF while the NAR non-pp is 5Q0511115AC.
Just an FYI if anyone else was wondering about this.
5G0853855B041 (left)
5G0853856B041 (right)
I don't believe they are compatible with the MK7 GTI though. It appears that the MK7 GTI and GTD share the same part. The MK7 GTI Clubsport and Golf R 7.5 appear to use the same part (as above part numbers). They are fixed to the car differently with additional bolts etc. so I doubt they will work on a MK7 GTI. Even if they did fit they are mega expensive. It would be cheaper to have your original ones painted gloss black.
Kunzmann also told me that a Clubsport GTI rear diffuser would fit my MK7 GTD as a straight fit without additional hardware which is incorrect. The part will fit but needs additional parts and fasteners which come on the MK7 GTI bumper but not the MK7 GTD bumper.
I'll have a look tonight to confirm but the side skirts are different and mount differently so are a different shape at least on the mounting side. On the outside they may very well look identical - same shape etc. but one in satin black/textured finish and one in a smooth gloss black finish but they are a different part outside of the paint I'm nearly sure. I'll double check and let you know.
I am having my original MK7 GTD side skirts painted gloss black this week so hopefully they will turn out nice. A lot cheaper than the €599 CS skirts that probably won't fit my car anyway too
