GOLF R SPRINGS ON GTI
First: My goal of doing this was to
1: Fix the factory suspension reverse rake
2: Lower the car slightly while not maintaining said rake
3: Enhance great driving experience
After a lot of research I found nobody who had actually done this....well I took one for the team. Research told me they would fit but how would it ride and how would they sit? I also could not find a set of springs that did not seem to solve the rake issue though the Driver Gear springs seems to be closest to what I wanted.
How I went about it:
Find Factory Spring Rates GTI:
Front - 175 lbs/in, Rear - 230 lbs/in
OEM Golf R Spring Rates:
Front - 195 lbs/in, Rear - 245 lbs/in
Eibach Pro-kit (R) Spring Rate:
Front 177 lbs/in, Rear 257 lbs/in
Seeing Spring Rates are very similar in front the ride should be close to factory (and it is) and the drop should be close to advertised (it is). The rear should be stiffer than stock but not jarring and the drop should be slightly less than advertised (it is)
2017 GTI-S DSG
Eibach Golf R; E10-85-041-01-22
Front Drop- 7/8"
Rear Drop- 5/8"
I now have a 1/4" Rake (front lower than rear)
Very happy with how it rides, feels and looks! Rear is much more planted...I don't think a rear sway bar upgrade is needed anymore. Still running the stock struts/shocks but with the minimal drop I don't foresee an issue. Hope my experimenting helps out fellow enthusiasts. Any questions feel free.
Thanks
Evan
Sent from my XT1254 using Tapatalk
