quailallstar
WOB DJ496
- Florida & our Nation's Capital
- MY19 MK7.5 GTI Bunny
Well, i finally got around to fitting the rear door warning lights on my GTD. Very straightforward as it turned out.
Postive wire goes to terminal 2 of the electric window motor cable block in the front centre of the door panel. The negative goes to terminal 5 of the door lock module connector at the rear top edge of the door. Note that for the drivers side, cable no 5 is second from the top as you look at it, however on the passenger side, its in exactly the same position (i.e. second from top) but the connector number run top to bottom (rather than bottom to top on the drivers side), so its actually marked terminal #2 on the passenger side not #5 (if that makes sense).
Who thing took about 1 hour for both doors. Wiring details below (drivers side) and images after the installation as well as a little video. Hope you like.
Movie
https://flic.kr/p/vgpC7y
Just did this mod on a NAR spec Golf Estate and noticed something interesting. My rear windows are no longer one-touch. Both using front switches and rear. In addition, I can no longer open / close my windows via the key fob wirelessly. Is this something expected after performing this mod per your instructions? Something I need to do in order to reset or retrain the windows? Thanks!
