zoominms3
Buffalo NY
zoominms3
Buffalo NY
What Diggs said, dangerously lean up top. You're also pushing +9 over 6000rpm. Need to take some off the top, and have room to add some in the middle between 4000-4500.
am I ok to run map 2 or should I be working on custom map 6 settings?
zoominms3
Buffalo NY
Relog map6. Might as well set FOL to 50 too.
Should I change my boost values while I'm tinkering? And I will change that to 50 as well.
Thank you :)
demi9od
NC
You're still seeing over 15 AFR on map 2, you need more fuel.
Edit: Saw you fixed your bias, that should do it.
zoominms3
Buffalo NY
Thanks, good looks! Going to run another log.
Let's see what it looks like first before tinkering. Stay with map6.
Thanks! Going to run a log now. Trying to find a good place to run in daylight lol. Side note I can get my hands on e85 as well. But I'm guessing add that in later?
zoominms3
Buffalo NY
Diggs24
de plains! de plains!
2015 GTI
I will worry about the ethanol map in the spring / summer.
Alright heres the updated log
https://datazap.me/u/zoominms3/map-6-afr-fix?log=0&data=1-2-3-4-25-27
AFR set to 100
FOL set to 50
1500 15
2000 16
2500 17
3000 21
3500 24
4000 22
4500 21
5000 20
5500 20
6000 20
6500 19
7000 18
Unless you plan on doing a clutch soon I would recommend turning it down in the lower rpm. Higher has to go down as well due to timing drop.
1500 15
2000 16
2500 17
3000 19
3500 22
4000 22
4500 21
5000 20
5500 18
6000 17
6500 16
7000 15
zoominms3
Buffalo NY
I figure next spring I will do an upgraded clutch, but for now would like to try and save it a little. I never launch the car or run from a dig, always roll into it. :)
AFR set to 100 from 0
FOL set to 50 from 40
67* ambient temp
1500 15
2000 16
2500 17
3000 19
3500 22
4000 22
4500 22
5000 20
5500 18
6000 17
6500 16
7000 15
https://datazap.me/u/zoominms3/fine-tuning?log=0&data=1-4
Diggs24
2015 GTI
67* ambient temp
1500 15
2000 16
2500 17
3000 19
3500 22
4000 22
4500 22
5000 20
5500 18
6000 17
6500 16
7000 15
1500 15
2000 16
2500 17
3000 19
3500 21
4000 21
4500 22
5000 20
5500 18
6000 16
6500 16
7000 15
This should be good to get you through winter without issue. No need to log.
zoominms3
Buffalo NY
1500 15
2000 16
2500 17
3000 19
3500 21
4000 21
4500 22
5000 20
5500 18
6000 16
6500 16
7000 15
Thanks man! I appreciate it! :)
Diggs24
2015 GTI
