spielwurfel
- São Paulo, Brazil
- Golf MK7 2014
Not quite...I believe that's the drain pipe for the intake. Someone else can correct me if I'm mistaken.
Not quite...
I believe that it's a police connected to the PCV system. At least that's what it's for on my 2.0t engine.
Not quite...
One more helpful video I found:
https://youtu.be/Zj-_bAiPq9Y
Could be. I'd check around the engine bay to see if there's a loose hose somewhere.So from what I got this hose is there for this secondary air inlet system, but VW thinks we don't need it here in Brazil and didn't install the system on the cars sold here.
Makes sense considering temperatures here are higher and in the winter we hardly get temperatures lower than 10C, since the system is made to speed up Cat heat.
Thanks =)
May also help to visit a local dealership and check under the hood of a few cars and see if they look the same or not.
