Poison Potato
- Pittsburgh
I tried searching and couldn't find whether or not this is possible.
With OBDeleven I coded the passenger mirror dip in reverse, and it functions as expected (2017 US GTI Sport).
Is the MKVII GTI capable of mirror dipping on the driver side, and if so, can someone tell me what I may need to do?
I followed the same steps in an attempt to do the driver door, but instead of going to '52 Passenger Door' I went to '## Driver Door'. The same 'bits' (2 and 3) were in the Driver Door menu so I was hoping that once activated, the driver mirror would also dip (when in the 'L' position). But after I activated, the mirror did not dip like the passenger mirror.
Instructions I followed for the mirrors:
Passenger Mirror Dip
mirror switch has to be on the passenger setting for it to work.
THEN
- 52 Passenger door
- 07 coding
- Byte 4
- Enable bit 2 and 3
THEN
- 09 Central Electronics
- 31347
- Adaptations
- 17-Access control 2 Spiegelabsenkung bei Rueckwaertsfahrt (change to “active”)
- (22) Access control 2-Menuesteuerung Spiegelabsenkung (change to “active”) this puts the option in the menu screen.
