Removing dealer stickers
Richard Mk7
West London
I was thinking the same about mine. I'm not a sticker person, so I might ask the dealers to leave the sticker. Will save me the effort trying to remove it.
AMPJ8
Europe
I had that issue with one of my Ducati's and I took a hair dryer to warm the sticker up then gently removed it without having to subsequently remove the glue.
I assume it would be the same with the stickers over the paint.
I do have a "GOLF CAR OF THE YEAR" sticker inside of the rear glass on the trunk. So far it is ok have not removed it. Will see.
DW58
I had one of these - plus a dealer sticker on my car on delivery day
Both were removed soon afterwards. Whilst the "GOLF CAR OF THE YEAR" was easily removed with no residue being left, I suspect this would be a different story if left for a longer period as these stickers often become very sticky.
bertj
Wirral (UK)
Warm it with a hair dryer then use dental floss or fine fishing line to 'saw' between the sticker and the glass - hold either end of the floss/line using gloves as it will be very painful on the fingers. This should remove the sticker but you will be left with the sticky goo. Sounds a bit extreme, but use a petrol soaked rag to remove the adhesive. BTW this is the method used when de-badging manufacturer's adhesive badges because the floss etc. won't damage the paintwork.
Mark V1
Herts, UK
bertj - good point re badges affixed to paint - but the stickers being discussed here are on glass - so other more effective methods such as a glass scraper can be used that would not be appropriate on paint.
DW58
What you have described is certainly the method normally used for de-badging bodywork, but seems a bit odd to me as a method for removing stickers.
Using petrol (gasoline) is a bit extreme as it will often dissolve both the adhesive and possibly the sticker itself in some cases - this is why I suggested using a specialist solvent designed for the purpose.
bertj
Wirral (UK)
bertj - good point re badges affixed to paint - but the stickers being discussed here are on glass - so other more effective methods such as a glass scraper made can be used that would not be appropriate on paint.
Quite correct of course, but I would be worried about using a scraper in case it slipped and gouged the paintwork. Being somewhat ham fisted that would probably happen to me!
burso
United Kingdom
Dazza, I have the same issue. However, I think those circles are from the suction pads the factories use to put the windscreen in place. Some glass cleaner should do the trick.
Those rings are quite annoying. Didn't manage to do anything about them in almost 6 months. :eek: Will ask my valeter to try to remove it.
Wolly
York
Some IPA (not the beer kind) should do the job for both the sticker glue and sucker rings
JohnV1
Midlands
Had the same, Rob. Pealed off the "car of the year 2013" & dealer sticker and chucked them both.
After each service they keep sticking a reminder on the windscreen - that also gets pealed off and chucked. Flamin' nuisance.
For any glue residue, I just use a drop of WD40. Shifts any gum/glue with a bit of elbow grease.
DW58
Yup - those "next service due" stickers don't usually even survive the trip home, in fact the last one was peeled off and handed to the Service Manager - surely that's why the Golf tells you when it needs servicing, the sticker is a bit of an "Uh hello" moment surely?
