travicon
- Houston, Tx
That wouldn't create the clunking.
I would've been careful going too tight with them though, the bolt holes/nuts on the mounts aren't that strong & can strip if overtightened. But they won't create any issues if they're "too tight"
See post #18 here:
http://www.golfmk7.com/forums/showthread.php?t=26688&page=2
I would've used the OEM mounts instead
Thanks for the help. I replied directly below that post #18. I had read good things about the 034 which is why I went for those, but I think I got my situation sorted out. A local guy that does a lot of installs for people told me his gut feeling was that it was the nut at the top of the strut so I decided to really just go for it this afternoon and it seems to have remedied the issue about 95%. I saw a method on another post of a guy that used a channel lock to hold a 21mm socket on the nut and then used a 7mm hex to tighten it all down(don't have to remove anything to work on it) and hit it pretty good and the problem was vastly improved. If I had a torque wrench I could probably remedy it once and for all but I'm happy to have it 95% until I can get to a torque wrench.
