MB's GLA45 AMG is rated at 375 HP. Anyone think they're lowballing?
I've been told that dynos are inaccurate
The Alltrack puts out 170 crank HP according to some dynos and 200 wheel HP according to others. Which is accurate? The one that makes owners feel better?
if that is you in your Avatar I ain't ashamed.....
Yes.
247 hp and 327 tq. The dark green numbers.
Sent from my SM-G930W8 using Tapatalk
If ypu werent so myopic this wouldnt be so hard to grasp.This is hilarious a point of fact that sells cars and you actually believe they would purposely understate it and then expect me to provide proof when the only proof you need is does VW like to sell cars? If the answer is yes than that proves it
1 question, what us VWs largest market? Hint, it isnt the US. They set the rules based on that market, and cant rate the same cars wildly differently in other markets.
Look at every other german auto maker and how their cars dyno vs what they rate, it's a simple pattern to see. Bmw 435 puts 332hp to the tires bone stock when they rate at 325 (mppk car). I just watched a C63S with 150 miles that makes a stated 503hp put 479 to the tires.
If you stick one toe outside your dense little world you would see this is very common in certain brands, and explains how "lower power" cars are shockingly fast.
Sent from my SAMSUNG-SM-G920A using Tapatalk
I had it on the low setting. I don't remember off hand what it is. I'm not sure how it compares to a JB4 but it works very well.Really makes me wonder how my 220 HP 2017 SE would dyno stock on the same dyno.
Also, I run a neuspeed at the +7 setting, what setting did you run yours on?
It would not surprise me if I were putting down 340+ ft/lbs to the wheels, pulls like a freight train.
Ok, so I could expect about 260 WHP and 340 ft/lbs on +7 then.
Not bad but I think ill still go APR stage 1 at some point.
