I've read on the Interweb that if you install a cat-less downpipe on an iPhone X it starts to smell like sulfur.
Can we use 45 degree angled spacer to mitigate that issue?
Spacers don’t affect smell
So the best DP that doesn't trigger a CEL is the AWE? Assuming I don't want to fart around with spacers, etc.
If you like cracked welds and your pipe to explode bwhahahahaha
How about stop behaving like an asshole and answer the guy question ? Isn’t that the whole idea of having a forum where people with common interests come for advise ? Are these forums even moderated ?
I did answer his question. That actually happened.
nope you did not answer his question.
for ecsta, yes AWE has NO CEL guaranteed and verified by all AWE DP owners.
Yes, one DP failed at the weld
Does that still hold true on the stock ecu? or is stage 1/2 required for the DP? Just thinking of not doing everything at the same time, if there's any drawbacks or if i should just wait and do tune + DP at the same time.
AWE guarantee no CEL with stock ECU (no tune required). If you are not planning to tune for a while, this might be the best option and the only drawback is cost.
Incase you are planning to get a tune in the near future, it would be better get both done together (you will save some money). Example, APR offers additional discounts when you buy their downpipe and opt Stage 2.
Actually, stage II is free with the DP if upgrading.
Upgrade from Stage 1 to Stage 2 is free, but you still need to pay for Stage 1.
