Gogo GTI
- Boulder, CO
- 2017 GTI Sport
Just wanted to confirm I got the right springs for my car: 2017 GTI Sport, DSG, 4 door, no DCC
071 675 B and 071 676 C
Thanks!
Thanks!
Thanks!
071 675 B and 071 676 C are not the kit part numbers. These are the 'part numbers'
of the corresponding springs which are part of the/a kit. Kit part numbers start with
'5G' since they are designed for the Mk.7 Golf (for which the internal codes are both
'5G' and 'AU'), while the 'spring part numbers' that are printed on each spring start
with 'MUB' (for Mubea who is the manufacturer). See the picture below and you'll
realize that 'MUB 071 675 B' and 'MUB 071 676 C' are part of the '5G4 071 677 E' kit,
which is the only DG kit available in the US anyway.
Yup that's exactly what I was trying to confirm. I bought the 5G4071 677 E kit from someone. The kit number is listed on the box, but I just wanted to make sure that the Mubea numbers printed on the actual springs were legit. Can't be too careful buying things from strangers.
Figgy, to be honest I'm wondering about your confusion. If I remember correctly we
had the exact same discussion some time ago. Didn't you already try 'IRS springs'
on your 'torsion beam Golf'? Didn't you already experience an odd rake due to these
wrong springs? Didn't I already tell you which kit would have been the right one at
that time? Obviously there are dedicated springs existent for your Golf because it is
no less than mandatory to use the correct ones, since torsion beam axle Golfs need
shorter springs than 'IRS Golfs':
Yeah I hear you loud and clear trust me breaking badly. I'm gonna call the service dept to see if they can tell me what the actual MUB part numbers are on the spring kits before I purchase. If they can guarantee the correct PNs as per TUV spec sheet then I should be good to go. Thanks again for all your help.
Some of yall may have seen my name hop everywhere in the forums asking about springs, but tonight I finally pulled the trigger and confidently ordered some DG Springs after much debate. Should be in this week and will install them end of next week.
On a side note, NA spec Golf TDI = torsion beam rear axle.
From what I remember DGs for torsion beam are hard to obtain in the US.
