arrived today, 30mins later installed and working (being really careful so if you rushed it may be able to do it faster) not a hard job.
*one thing to note is my JDM golf needed to do that USDM plug shave deal with the inner/tail gate connectors into the audiamant adapters. So Aus cars may run into the same sort of thing.
the coding was not a problem with OBDeleven.
Just to make sure I understand, you do not have a US spec car correct?
What did you use for coding instructions?
Crild, I got my set yesterday but haven't opened the box yet....kid stuff had me busy.
thats correct, Im in Japan so have the JDM model Golf R. Im not sure which other regions share the same type but its a hot climate model so I would assume if any Australia/NZ would be the same as they are also hot climate and right hand drive.
JDM models are ROW since they have LED standard, makes adapters and coding a hell of a lot easier vs the NAR cars.
Page 3 or 4What are the product numbers for the 7.5 taillights you guys are getting from cars245? I saw them posted but cant find it now. Thanks
sorry forgot to answer this question. They send a set of coding (pretty basic, 17 line changes) the JDM cars require the same as the euro cars. Was able to be done via OBDeleven.
Looks tits. Luckily your adapters are easiler to install [emoji17]
Received from audiamant today. Took almost 2months including 3weeks of delivery time to get here in Australia. Almost spent 2hours including some coding tweaks and they are worth every single penny. [emoji108]
Sent from my SAMSUNG-SM-G935A using Tapatalk
